I found a case where I will get warnings on one compile, but when I immediately hit the [compile] button again, there are no warnings.
To recreate, make a new project and paste this code into main.cpp:
#include <string>
#include <sstream>
string intToStr(int i){
stringstream ss;
ss << i;
return ss.str();
int i=10;
string str=intToStr(i);
printf("number %i as a string = %s\n", i, str);
} Compile this and you'll get a few warnings, which makes sense because the use of str in the last line is a little sloppy. Change it to the more correct:
printf("number %i as a string = %s\n", i, str.c_str());
(If the forum strips out the #includes, I'm including string and sstream)
And compile. I see the following two warnings:
"<__c.0> may be used before being set" in file "/opt/RVDS4/RVCT/Data/4.0/400/include/unix/rw/_ioiter.h"
"<__c.0> may be used before being set" in file "/opt/RVDS4/RVCT/Data/4.0/400/include/unix/streambuf"
But if I immediately hit compile again I get no warnings at all. If I make any edits to the code at all it throws the warnings again, even just adding a comment. But, again, if I compile a second time with not changes there are no warnings.
(This happened under Win XP, Chrome 6, Firefox 3.6 and IE8 using both the current and the beta compiler.)
#include "mbed.h" #include <string> #include <sstream> string intToStr(int i){ stringstream ss; ss << i; return ss.str(); } int main() { int i=10; string str=intToStr(i); printf("number %i as a string = %s\n", i, str); }Compile this and you'll get a few warnings, which makes sense because the use of str in the last line is a little sloppy. Change it to the more correct:
printf("number %i as a string = %s\n", i, str.c_str());(If the forum strips out the #includes, I'm including string and sstream)
