I'm currently doing offline development with the mbed SDK, and noticed it fails to build under certain condition with a following error:
# python build.py -t GCC_ARM -m LPC1114 -o debug-info -r
Building library RTX (LPC1114, GCC_ARM)
Compile: rt_CMSIS.c
[Error] rt_CMSIS.c@588: In function 'osKernelInitialize': r7 cannot be used in asm here
c:\src\mbed\libraries\rtos\rtx\rt_CMSIS.c: In function 'osKernelInitialize':
c:\src\mbed\libraries\rtos\rtx\rt_CMSIS.c:588:1: error: r7 cannot be used in asm here
Culpit is the following code in rt_CMSIS.c:
#if (defined (__CORTEX_M0)) || defined (__CORTEX_M0PLUS)
#define SVC_Call(f) \
__asm volatile \
"ldr r7,="#f"\n\t" \
"mov r12,r7\n\t" \
"svc 0" \
: "=r" (__r0), "=r" (__r1), "=r" (__r2), "=r" (__r3) \
: "r" (__r0), "r" (__r1), "r" (__r2), "r" (__r3) \
: "r7", "r12", "lr", "cc" \
#else
Cortex-M0 LDR has a limitation that it cannot directly load value into upper register (r12), and that's why r7 is being used as a temporary register. However, that breaks GCC on debug build since GCC is also using r7 as frame pointer.
An easy fix would be to change r7 into something else in lower register, say r6.
However, to avoid writing temporary register name in asm, following code may be better:
#define SVC_Call(f) do { \
register int tmp; \
__asm volatile \
"ldr %[tmp],="#f"\n\t" \
"mov r12,%[tmp]\n\t" \
"svc 0" \
: [tmp] "=r" (tmp), "=r" (__r0), "=r" (__r1), "=r" (__r2), "=r" (__r3) \
: "r12", "lr", "cc" \
} while (0)
#if (defined (__CORTEX_M0)) || defined (__CORTEX_M0PLUS) #define SVC_Call(f) \ __asm volatile \ ( \ "ldr r7,="#f"\n\t" \ "mov r12,r7\n\t" \ "svc 0" \ : "=r" (__r0), "=r" (__r1), "=r" (__r2), "=r" (__r3) \ : "r" (__r0), "r" (__r1), "r" (__r2), "r" (__r3) \ : "r7", "r12", "lr", "cc" \ ); #else ...Cortex-M0 LDR has a limitation that it cannot directly load value into upper register (r12), and that's why r7 is being used as a temporary register. However, that breaks GCC on debug build since GCC is also using r7 as frame pointer.
An easy fix would be to change r7 into something else in lower register, say r6. However, to avoid writing temporary register name in asm, following code may be better:
#define SVC_Call(f) do { \ register int tmp; \ __asm volatile \ ( \ "ldr %[tmp],="#f"\n\t" \ "mov r12,%[tmp]\n\t" \ "svc 0" \ : [tmp] "=r" (tmp), "=r" (__r0), "=r" (__r1), "=r" (__r2), "=r" (__r3) \ : "r" (__r0), "r" (__r1), "r" (__r2), "r" (__r3) \ : "r12", "lr", "cc" \ ); \ } while (0)
