Hi Emilio,
This was the second thing I tried. I'm running revision 5 of mbed-rtos (2 weeks, 2 days old). If I try to force the library to the latest version again I get a warning message saying:
'Unable to update library to revision: /DataLogger/mbed-rtos/rtos
Unable to update library to revision: /DataLogger/mbed-rtos/rtx'
Trying to move between revision of mbed-rtos kept giving the same issue. I removed the mbed-rtos library and re-imported it. Now I get the following error:
"invalid redeclaration of type name "BOOL" (declared at line 27 of "/workspaces/DataLogger/src/FATFileSystem/integer.h")" in file "mbed-rtos/rtxos_tcb.h", Line: 14, Col: 27
Joe
I tried recompiling some code this morning that was working prior to the move yesterday. What compiled correctly now gives me the following error:
"struct "os_thread_def" has no field "stack_pointer"" in file "EthernetInterface/lwip-sys/archsys_arch.c", Line: 429, Col: 11
I've removed the EthernetInterface library and added it again to see if that clears the error but it didn't work.
I've using the latest release of EthernetInterface.
Joe
