Hi everybody,
1. I just found out that the mbed OS 5.2.1 release of Oct 2016 (realease 128) introduced an issue on the nRF51822 - The non-triggering of InterruptIn associated callbacks. I'm testing this with setting .rise() upon one of these variables, associated to a physical button. The device doesn't react to the button's click since this release.
2. In another hand this release corrected an issue on the same microcontroller - Before this release the device would apparently go to sleep (stopping to transmit BLE signals and to react to InterruptIn's) after 8 to 10 minutes from booting.
Does anybody have a hint on which may be the cause of the issue (1.) or which part of the mbed OS 5.2.1 release has been responsible to solve issue (2.) so that I can fork from the previous release?
Thanks!
#define FPU_EXCEPTION_MASK 0x0000009F
#ifdef NRF52
/* Clear exceptions and PendingIRQ from the FPU unit */
__set_FPSCR(__get_FPSCR() & ~(FPU_EXCEPTION_MASK));
(void) __get_FPSCR();
NVIC_ClearPendingIRQ(FPU_IRQn);
#endif
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
#include <sstream>
#include <string.h>
#include <string>
#include <vector>
#include <ctime>
#include "ble/BLE.h"
#include "EddystoneService.h"
extern "C" {
#include "softdevice_handler.h"
#include "nrf_error.h"
#include "nrf_ble_gap.h"
#include "app_scheduler.h"
* Global Variables
EddystoneService * eddyServicePtr;
static bool triggerA = false;
static bool triggerB = false;
static DigitalOut alivenessLED(LED1, 1);
int scoreA = 0;
int scoreB = 0;
InterruptIn buttonA(p4);
InterruptIn buttonB(p5);
void bleInitComplete(BLE::InitializationCompleteCallbackContext* initContext)
BLE &ble = initContext->ble;
ble_error_t error = initContext->error;
if (error != BLE_ERROR_NONE) {
onBleInitError(initContext);
return;
/* Set everything to defaults */
eddyServicePtr = new EddystoneService(ble, defaultAdvPowerLevels, radioPowerLevels);
/* Updates the current_match_url with the current match score */
const char *current_match_url;
/* Set default URL, UID and TLM frame data if not initialized through the config service */
eddyServicePtr->setURLData(current_match_url);
eddyServicePtr->setUIDData(&uidNamespaceID, &uidInstanceID);
eddyServicePtr->setTLMData(tlmVersion);
/* Set battery voltage and temperature callbacks */
eddyServicePtr->onTLMBatteryVoltageUpdate(tlmBatteryVoltageCallback);
eddyServicePtr->onTLMBeaconTemperatureUpdate(tlmBeaconTemperatureCallback);
/* Adjusts TXPower to a higher setting */
ble.gap().setTxPower(4);
/* Adjusts the advertised name */
ble.gap().setDeviceName("GoaloriaDevice");
/* Start Eddystone in config mode */
eddyServicePtr->startBeaconService(1, 0, 0);
void trigA() {
triggerA = true;
alivenessLED = true;
void trigB() {
triggerB = true;
int main(void) {
buttonA.rise(&trigA);
buttonB.rise(&trigB);
BLE& ble = BLE::Instance(BLE::DEFAULT_INSTANCE);
ble.init(bleInitComplete);
/* SpinWait for initialization to complete. This is necessary because the
* BLE object is used in the main loop below. */
while (ble.hasInitialized() == false) { /* spin loop */ }
while (true) {
if (triggerA) {
/* Do blocking calls or whatever hardware-specific action is
* necessary to poll the sensor. */
wait(1);
/* Set Score */
scoreA = scoreA + 1;
/* Updates the Eddystone URL Frame */
ble.shutdown();
delete eddyServicePtr;
triggerA = false;
alivenessLED = false;
if (triggerB) {
wait(1);
/* Set Score */
scoreB = scoreB + 1;
ble.shutdown();
triggerB = false;
ble.waitForEvent(); /* this will return upon any system event (such as an interrupt or a ticker wakeup) */
Hi everybody,
Thanks!
