1 year, 7 months ago.
bug: Thread terminate does not cleanup memory.
As far as I've tested I've noted that the termination of a thread does not call the destructor of any classes that were created inside the function running the thread. See the test code below and the output below that. I'd expect `~Test` to be printed there as well!
I've also tried using a pointer to the thread and delete that after terminating but I couldn't get the destructor to be run. Does this mean that this is a memory leak? I.e. when I use a pointer and run the thread for a wile before terminating it and creating a new thread will leave all the stuff allocated inside the thread function in memory? And how can I get the desired behaviour of calling the destructor being called?
test code
class Test {
 public:
  Test() { printf("Test\n"); }
  ~Test() { printf("~Test\n"); }
Thread thread;
void led2_thread() {
  Test test;
  while (true) {
    printf("Hi!\n");
    rtos::ThisThread::sleep_for(100);
  thread.start(led2_thread);
  rtos::ThisThread::sleep_for(500);
  printf("Terminate: %ld\n", thread.terminate());
  while (true) {
Output
Test
Hi!
Hi!
Hi!
Hi!
Hi!
Terminate: 0
