3 years, 2 months ago.
How to find the R-peak location of an ECG using MAX30003 AFE
Hello all.
I am trying to find the locations of R-peaks from an ECG recording.
From what I have read in the datasheet for MAX30003 AFE, the device offers the R-to-R duration. This duration is updated on every R-peak detected. The info about the R-events should be stored in the STATUS register within the RRINT bit.
When I try and access this bit to learn the location of R peaks, some peaks (most even) are not detected. Please find the picture below.
/media/uploads/drenaj/capture.png
However, to try and get around this, instead of accessing the RRINT bit, I observe the R-to-R duration in order to find the R peaks. Whenever the duration value changes, a peak has been detected. The problem then is that, if the duration of 2 consecutive beats is the same, I cannot find the peak.
Now as the R-to-R duration is changing, I know that there is an accurate way to find the peaks. But, I do not know where to find this information.
Any help is welcome at this point.
Some information (if required):
Platforms used: MAX30003 AFE, MAX30003WING, MAX32630FTHR
Sampling rate: 128 sps
Input signal: ECG generator set to sinus arrhythmia
Thank you very much in advance!
Andrej
3 years, 1 month ago.
Firstly its RR resolution is 8 ms. Additionally Pan-Tompkins algorithm executed at hardware level is a little bit late in finding the treshold compared to software level Pan-Tompkins algorithm.I recommend you to wait at least 30 seconds (may be longer). As the threshold is approximated efficiency of R detection improves.
