6 years, 7 months ago.
Is there any serial port compiler as I am not able to run the program "Hello World" on my laptop
I am unable to print even the easiest program like hello world because I think there is some issue with serial port although, I can print stuff on my NXPLPC1768 . Is there any serial port compiler that you guys can give a link of. Would be a lot of help.
Regards.
What do you mean with "serial port compiler" ? Have you checked that the device appears in Device Manager (on Windows), have you checked that the baud rate is the same on both device and computer? Does the program actually run on your board (e.g. does blinky work)?
posted by Jan Jongboom 27 Sep 2017
