4 years, 4 months ago.
Is it possible to run ticker object for more than 30 min?
I want to read log adc samples with a sampling rate of 0.01 seconds. So I used a ticker to create a timer and print adc data on terminal. But it is observed that about after 30 mins the terminal stops displaying any data on it. I use NRF52 microcontroller. Is it possible to using ticker object for more than 30 mins duration(I need around 8 hours data sampling continously)?
Yes, it should work. Otherwise it is a bug. Since the NRF timer code has been one large bug in the paste, are you running the latest mbed version?
posted by Erik - 03 Sep 2017
Hi Erik. Yes, I am using latest version of mbed.
posted by Manoj G. 04 Sep 2017
Internally the Ticker object (and Timers and Timeouts) uses a int32_t to count time in us. 2^31 us = 35.79 minutes.
If you need a lower resolution clock to run for a longer time then the best solution is to set a Ticker or Timeout to run at a 1ms rate and then use that to create a clock that gives you 1ms resolution. That will then give you just under 25 days before you need to worry about roll overs.
Hi Andy, Thanks for your answer. But I don't get it how I can change the resolution of the ticker object. Is it possible for you to paste a code snippet on how to set resolution to 1 ms? Or do you mean to say to use ticker object instead of ticker_us object for running code? Regards, Manoj
You don't change the resolution. Ticker and Ticker_us are two ways to configure the same thing.
You create your own counter either as an object or a counter that runs at whatever speed you want.
posted by Andy A 04 Sep 2017
Well, Thanks for the help. Finally I found it was not the problem with Ticker object rather it was some other problem. May be with BLE, included in my code. Regard, Manoj.
