9 years, 10 months ago.
how to flash mbed for FRDM k64 board?
Hello all, I am using FRDM k64f board which comes with mbed firmware...but it got corrupted..can anyone suggest how to recover it or how do i flash latest mbed firmware on FRDM k64f?
Thanks, Shweta
Have tested this?
https://developer.mbed.org/platforms/FRDM-K64F/#firmware-update
Hello Motoo, whwn i connect my board its not showing MBED...so how to get MBED on board..can u suggest?
posted by shweta karade 10 Jun 2016
May be, you have already done so, but did you push and keep the reset switch when you connect your board to PC?
If you did so, you should see your board as Bootloader from PC and if you do not see it so, something has gone very wrong...
posted by Motoo Tanaka 10 Jun 2016
If you can see your board as Bootloader, then follow
https://developer.mbed.org/handbook/Firmware-FRDM-K64F
If you can not see your board as Bootloader may be you need to contact the dealer you get the board from ...
