Report
4 years, 2 months ago.
has anyone tried WiFi?
There's a WiFi module with an XBee form factor: http://imall.iteadstudio.com/im141118001.html
Has anyone tried this on the LPC4088?
(I can't try it here yet, still waiting for the Mac OSX upload to get fixed...)
-jcw
The mbed-enabled LPC4088 QuickStart Board from Embedded Artists is a easy to use ARM Cortex-M4 rapid prototyping board in a standard through hole DIP package (44-pin), targeted at high-performance as ...
Yes. I have tried.. But what happens. When i ON my wifi connection other unknow users are also connected to my wifi. Then i read an article about WifiKill. Download it and my problem is solved. Here is: How to download and install WifiKill for iOS: http://wifikillapki.com/download-wifikill-no-root/
posted by Sweta Sharma 28 Oct 2017
Comment on this question
4 months, 3 weeks ago.
Hello, , Wi-Fi is technology for radio wireless local area networking of devices based on the IEEE 802.11 standards. Wi‑Fi is a trademark of the Wi-Fi Alliance, which restricts the use of the term Wi-Fi Certified to products that successfully complete interoperability certification testing, If you face any issues then read Fallout 4 Won’t Launch On The PC Blog to get the best solution by the experts. https://laptopsupportnumber.co.uk/blog/fix-fallout-4-wont-launch-on-the-pc/
I was looking to do the same thing a couple of months ago but didn't get far with a day worth of effort, then had to focus elsewhere.
I wouldn't mind getting back on this to see what's possible. This post was a good reminder. I'll take a look at it over the next few days, maybe we can combine efforts? Are you still in the research phase or started working on it?
There are a couple of libraries available on embed which may be useful, but are for other manufacturers, I'll try to look and post some link...
There was a thread a while back about this. Maybe good if yall could pick this up and drive it forward!
http://developer.mbed.org/forum/team-165-components-community/topic/4844/
Take a look at this........
http://www.esp8266.com/
http://www.banggood.com/ESP8266-Remote-Serial-Port-WIFI-Transceiver-Wireless-Module-p-947259.html
https://github.com/genguskahn/ESP8266-For-DUMMIES
Very simple webserver or client UDP/TCP via AT commands or program as stand alone with serial commands in and out.....
Very Impressive addition to any MCU, just joined this forum finding my way around....
7 months, 1 week ago.
Has anyone done any range testing with this module, particularly with the antenna folded against the board? I’m considering using one of these to add a bit of network awareness to an 8-bit computer project, but I’m not sure if the wire antenna would be sufficient or if I should go for the RP-SMA version instead.
https://www.routertechnicalsupportnumbers.com/netgear-router-support/
To post an answer, please log in.
