You do not have the correct permissions to perform this operation. Please, contact us at support@mbed.com to gain full access.
I have been making an whole system in which it measures temperature every 5 minutes and stores it in an flash drive . The data could be accessed via the ethernet port over than local LAN. It also does serial port communication with the use of interrupt. All works normally fine. But after taking some 10-15 readings the mbed gets hanged and does not work then. What could be causing this? Does mbed have any sleep state which it might be going into?
