m3pi 8 leds
02 Dec 2011
How does one drive the 8 leds, on or off?
This is confusing for I see leds(int val)
How would I turn on 1st, and last, pin 20 and pin 13, and all the rest off?
Someone please try it.
Thanks, donde
02 Dec 2011
Hi Donde,
It's implemented as an 8 bit bus with one LED per bit, so you can use a bit mask - it is probably easier to think of in Hexadecimal rather than a decimal integer.
If you're a little rusty on Hexadecimal, check out :
Hope this helps, Chris
04 Dec 2011
Thanks Chris I realize that now, but looking at the m3pi cookbook, an example would have been helpful. But, look what I did above for the topic of "Knight Rider w/o wait." and without bit shift! I started it with just 4 LEDS, but had to finish it with 8. Not very efficient code, I suppose. donde
