Important changes to forums
We’re making some changes to the Mbed forums. From 10th December 2019 all new discussions will take place on our new forum site. You can continue to reply to existing threads for the next two weeks. After that we will archive this forum so you can return to useful posts in the future.
Starting a new BLE project
30 Oct 2014
Dear MBED community, I'm looking for a BLE compatible MBED plateform to make a design. Maybe you could help a beginner coming from the arduino world and wanted to go to production using MBED
1- As my project is cost sensitive. Is there somewhere a list on nRF51822 system on modules compatible with mbed and price comparaison?
2- For example imagine I choose this Redbear plateform for my prototype: http://store.redbearlab.com/products/blenano Then I want to go to production and buy tones of the module they are using MDBT40 directely to manufacturer RAYTAC http://www.raytac.com/products.php ,
Will I be able to upload the mbed bootloader using the REDLAB USB ? Then could I get read of the USB to do firmware update Over the air?
Thank you in advance for your answer !
05 Jan 2015
Dear Rosco, I am facing the same problem (Arduino background, stumbling across mbed - new horizons :D ), so did you have any luck with programming the MDBT4o so far? Best, Glycyl
25 Jan 2015
Hi, All,
May you can refer to our uCXpresso.NRF for nRF51822, the uCXpresso.NRF are RTOS C/C++ framework.
Getting Started: http://www.embeda.com.tw/ucxpresso/?article=getting-started-2
GitHub: https://github.com/ucxpresso/nano51822
04 Feb 2015
For nRF51822 platform you could use FOTA to minimize PCB and cost:
  • Develop on an nRF51822-DK with full mbed (newer nRF IC than mkit, though I'm still using mkit).
  • For production use FOTA which links wireless so doesn't need mbed IC, can be any nRF51822 PCB (best if have 32KHz crystal).
  • There are some very minimal nRF51822 PCBs available. Careful of:
    • battery drain during firmware upload (no issue if rechargeable product)
    • Bluetooth certification of product: Some modules are already Bluetooth certified which could reduce your cost going to production for products intended for mass market (versus just testing).
  • Note mbed nRF FOTA is still early stages, security needed to block hacking, or at least be able to disable DFU service until it is specifically enabled by user through matching app or button push on device. May not be good if anyone can use nRF MCP to load other firmware, or maybe that is an advantage for your product.
  • Some notes on setup non-mbed PCB with FOTA: http://developer.mbed.org/users/prussell/code/FOTA4/wiki/FOTA-Notes
You need to log in to post a reply
