You do not have the correct permissions to perform this operation. Please, contact us at support@mbed.com to gain full access.
Hi, I successfully started uploading helloworld and it worked fine. Now I uploaded another bin. Which one is the one executed after pressing reset? Didn't found an answer here! So I thought ok, remove the old bin. But it won't get deleted. Windows tells me the file is in use. So I unplugged USB and plugged in again. Now I deleted the file, but strangely the file is always shown in the FAT with 0 byte size. Some minutes and a few gray hairs later I deleted the file successfully. But now I can't upload anything anymore. The copy dialog doesn't finish. Reconnected several times without success. It's also not possible to format the flash using windows format utility. It just tries to access and nothing happens.
I'm using Windows 7 64bit.
Thanks in advance René
