Connect SD-Card to Nucleo F411RE
17 May 2017
Hello, I tried to connect nucleo-f411re to an SD-Card according to the diagram in https://developer.mbed.org/users/mimi3/code/wave_player_pwm_lite/
When all connected I’m getting failure for trying to open a file from the sd-card or write to it. I’m a newbie and appreciate any help.
This is what I did: /media/uploads/yatuvy/20170517_115505.jpg /media/uploads/yatuvy/20170517_115644.jpg /media/uploads/yatuvy/20170517_115611.jpg /media/uploads/yatuvy/20170517_115956.jpg /media/uploads/yatuvy/20170517_120221.jpg
That’s the text file I’m trying to read: /media/uploads/yatuvy/image20170516223701.png
This is the code:
SD Card Test
#include <fstream>
#include "SDFileSystem.h"
SDFileSystem sd(D4, D5, D3, D10, "sd");
			//(mosi,miso,sclk,cs,name)
char buffer[4096];
void readTest1() {
    printf("\n\rreadTest1() Read /sd/DirX/textfile.txt");
    FileHandle* file = sd.open("/sd/DirX/textfile.txt", O_RDONLY);
    if (file == NULL) {
        printf("\n\r\tFailed sd.open(...)");
    } else {
        printf("\n\rSuccess sd.open(...)");
void readTest2() {
    printf("\n\rreadTest2() fopen /sd/DirX/textfile.txt");
    FILE *fp = fopen("/sd/DirX/textfile.txt", "r");
    if (fp == NULL) {
        printf("\n\r\tFailed fopen(...)");
    } else {
        printf("\n\r\tSuccess fopen(...)");
void writeFile(){
    const char* filePath = "/sd/DirX/mydir/sdtest.txt";
    printf("\n\rwriteFile() Write to SD card: %s", filePath);
    mkdir("/sd/DirX/mydir", 0777);
    FILE *fp = fopen("/sd/DirX/mydir/sdtest.txt", "w");
    if(fp == NULL) {
        printf("\n\r\tFailed writeFile()");
    else{
        fprintf(fp, "\n\rSuccess writeFile()");
        fclose(fp);
	printf("\n\rSD Card Test");
	readTest1();
	readTest2();
	writeFile();
And the upsetting result: /media/uploads/yatuvy/image20170517123427.png
Thanks for any help :)
Import programSD_Card_Test-yonatan
Just a test for read/write operations on SD-Card, using Nucleo-f411re
23 May 2017
This post deserves a response, if only for the very clean photographs. I had SD card read/write working with mbed-dev "#define MBED_LIBRARY_VERSION 118" and "SDFileSystem.h" from a similar time period. I have the Nucle_F401RE though.
First thing. Do not Exit main(). Ever. I believe this is undefined and will definitely crash your program. Throw an empty loop in there if you need to.
while(1);
Then, be careful about spamming the SD card too fast. Throw some waits in there between calls to write and read.
Then when you make the directory, I think you need to make One directory at a time. As written it tries to create mydir inside DirX, but DirX doesn't exist yet and it's not smart enough to make Both directories for you.
I note in that Link, they are not showing SD ground connected. It needs to be connected so it is common with the micro. I have the same sparkfun breakout board. Every pin except CD is connected directly to my micro - no external resistors, not even any caps. CD is not connected anywhere.
Here, I tested this in online compiler with mbed revision 118 and SDFileSystem rev 23:6bb3c19 on F401RE board. Works. Pins of course are just how I have the breakout board connected. I rolled these libraries back to this point because I knew it worked. The latest version of each did not work out of the box and I did not want to investigate.
// https://developer.mbed.org/users/neilt6/code/SDFileSystem/
#include <stdio.h>
// #include <stdlib.h>
// #include "rtos.h"
SDFileSystem sd(D11, D12, D13, D10, "sd");
// (mosi,miso,sclk,cs,name)
void readTest2() {
    unsigned char c; // a single byte buffer
    sd.mount();
    printf("\r\nreadTest2() fopen /sd/DirX/sdtest.txt\r\n");
    FILE *file = fopen("/sd/DirX/sdtest.txt", "r");
    if (file == NULL) {
        printf("\tFailed fopen(...)\r\n");
    else {
        printf("\tSuccess fopen(...)\r\n");
      while (c != '\n') {
            c = getc(file);
            printf("%c\r\n",c);
        fclose(file);
    sd.unmount();
void writeFile() {
    sd.mount();
    const char *filePath = "/sd/DirX/sdtest.txt";
    printf("writeFile() Write to SD card: %s\r\n", filePath);
    int result = mkdir("/sd/DirX", 0777);
    if (result == -1) {
        printf("Could not create Directory.\r\n");
    // w = fresh write, a = append
    FILE *file = fopen("/sd/DirX/sdtest.txt", "w");
    if (file == NULL) {
    else {
        fprintf(file, "0,1,2,3,4,5,6,7,8,9\n");
        fclose(file);
    // should free card to be removed
    sd.unmount();
    printf("\r\n--- SD Card Test ---\r\n");
    writeFile();
    wait(0.1);
    readTest2();
    wait(0.1);
    // readTest2();
    // Do not exit main.
    while (true) {
        wait(0.5);
24 May 2017
Hi Graham, I tried connect SD to GND and also connect SD pins (mosi, miso, clk) directly to board. still getting Failed, also with your code.
But thanks anyway :)
02 Jun 2017
Please, could you try this example - https://github.com/armmbed/mbed-os-example-fat-filesystem and follow on to this section (https://github.com/armmbed/mbed-os-example-fat-filesystem#switch-from-ram-backed-block-device-to-an-sd-card) for the SD card? That way we can get a baseline for your setup, as we know this example code works.
Thanks, Sarah
19 Jul 2017
I'm having a similar issue using the ST Micro Nucleo-F446RE and the SparkFun microSD Transflash breakout. The connections that I'm using are.
SD BreakoutF466RE
CDPC_8
DOPB_14
GND<GND>
SCKPB_13
VCC+3.3V
DIPB_15
CSPB_1
I tried the example fat file system example that Sarah mentions above which works. When I switch to the SD card it fails. I decided to remove the FAT Filesystem out of the equation and try to use it as an SDBlock device and it fails on the .init method below with a -5005. The SD card is a formatted FAT 4GB sdMicro.
    // mosi, miso, sclk, cs
    SDBlockDevice bd(PB_15, PB_14, PB_13, PB_12);    //HeapBlockDevice bd(128 * 512, 512);
    uint8_t block[512] = "Hello World!\n";
    // call the SDBlockDevice instance initialisation method.
    int i = bd.init();
    // Write some the data block to the device
    i = bd.program(block, 0, 512);
    // read the data block from the device
    i = bd.read(block, 0, 512);
    // print the contents of the block
    printf("%s", block);
    // call the SDBlockDevice instance de-initialisation method.
    i = bd.deinit();
I'm using Mbed Library version 123 along with the VisualGDB toolset and Visual Studio 2013. I also have the Nucleo-F411RE if you want me to test with that one.
Thanks, -steve
24 Aug 2017
Hey Steve,
You will receive the most support for this if you use the latest version of mbed OS - 5.5.5 in that example. That way, if you do find a problem in that example (using the latest version of mbed OS), you can file an issue against mbed OS - https://github.com/ARMmbed/mbed-os/issues.
