I am using mbed to develop a small data logger, based on the NXP RD-KL25-AGMP01 platform:
http://www.nxp.com/products/sensors/gyroscopes/10-axis-sensor-data-logger-reference-design:RD-KL25-AGMP01
This hardware is based on the Kinetis KL25 microcontroller, and it has an OpenSDA debug interface, so I can make mbed code using the FRDM-KL25 platform as the base for it. I want to make a small acceleration logger, using the onboard microSD card connector and the FXOS8700CQ accelerometer/magnetometer combo, so I imported both SDFileSystem abd FXOS8700Q libraries.
My code has a calibration phase, where it collects the accelerations for 5 seconds and then calculates its average as an offset. Then, it opens a file in the SD card to save this offset and then start logging. However, the recorded accelerations were with their values all wrong. Also, I am using the green LED to blink after a certain number of samples, and it looks like the blinking period is dilated, which suggests a timeout in the accel readings. If I comment out all lines that control the SD card (sending data through serial to check it out), everything works fine. If I add just an fopen command, readings are wrong again. All readings before the fopen command are right.
So I believe there is some strange interaction between SPI and I2C interfaces when using mbed, and I have no idea on how to fix it.
The code is below. I am using the mbed-dev library, modified to change function of RESET pin, but I have also tried using the normal mbed library (just logging data without any command button), and the result is the same.
Here is the code
/* THIS PROGRAM USES A MODIFIED MBED-DEV LIBRARY!
THE RESET BUTTON IS USED AAS A COMMAND PUSH BUTTON, FOR THIS THE STARTUP FILE WAS CHANGED
SO THE FOPT REGISTER STARTS WITH THE 0xF7 VALUE (RESET DISABLED
#include "FXOS8700Q.h"
#include "SDFileSystem.h"
FXOS8700Q_acc acc(PTC2, PTC1, FXOS8700CQ_SLAVE_ADDR0); // Proper Ports and I2C Address for RD board
// RGB LED
DigitalOut LEDR(PTB0);
DigitalOut LEDG(PTB1);
DigitalOut LEDB(PTD6);
DigitalIn detect(PTD4); // SD card inserted detection; logic level H if inserted
DigitalIn SW(PTA20); // Using RESET button as a command push button
SDFileSystem sd(PTC7, PTC6, PTC5, PTC4, "sd"); // Filesystem for SD card
char mainaxis = 0; // indicates axis at vertical: 1 for X, 2 for Y, 3 for Z
bool osc = false; // flag to indicate oscillation
FILE *fp; // File pointer
int16_t raX, raY, raZ; // Raw acc data
int32_t sx, sy, sz; // sum of samples for average during callibration
int16_t mx, my, mz; // averages for callibration
char k = 0;
LEDR = 1;
LEDG = 1;
LEDB = 1;
while(SW); // wait for button press
acc.enable();
LEDB = 0;
sx = 0;
sy = 0;
sz = 0;
for(k = 0; k < 125; k++) { // 125 samples, 40ms between them, total 5 seconds
acc.getX(&raX);
acc.getY(&raY);
acc.getZ(&raZ);
sx = sx + raX; // adding all samples
sy = sy + raY;
sz = sz + raZ;
printf("%d, %d, %d\r\n", raX, raY, raZ);
wait_ms(40);
mx = sx / 125; // average
my = sy / 125;
mz = sz / 125;
// Defining the gravity axis
mainaxis = 1;
if(abs(my) > abs(mx)) mainaxis = 2;
if(abs(mz) > abs(my) && abs(mz) > abs(mx)) mainaxis = 3;
k = 0;
if (detect) {
//fp = fopen("/sd/osclog.txt", "w"); // open file if there is sd card
//fprintf(fp, "OSCILLATION LOG\r\n");
//fprintf(fp, "MEDIAS: %d, %d, %d\r\n", mx, my, mz);
//fprintf(fp, "Main Axis: %d\r\n", mainaxis);
//fprintf(fp, "--------------------------------------------------\r\n");
LEDB = 1;
while(SW); // wait for button press to start logging
wait(0.1);
while(!SW);
wait(0.1);
LEDG = 0;
while (SW) {
acc.getX(&raX);
acc.getY(&raY);
acc.getZ(&raZ);
s = false;
raX = raX - mx;
raY = raY - my;
raZ = raZ - mz;
if (detect) { // record sample if there is SD card
//fprintf(fp, "%d, %d, %d\r\n", raX, raY, raZ);
k++; // toggles green LED every 1 second
if(k > 24) {
k = 0;
LEDG = !LEDG;
wait_ms(40);
LEDG = 1;
if (detect) {
//fclose(fp); // close file
Here is the code
