Important changes to forums
We’re making some changes to the Mbed forums.
From 10th December 2019 all new discussions will take place on our
new forum site.
You can continue to reply to existing threads for the
next two weeks. After that we will archive this forum so
you can return to useful posts in the future.
can't open compiler
Topic last updated
12 Oct 2010, by
Ben Zijlstra.
12
replies
When I open compiler I get an error "ERROR: Failed to initialize control objects.Failed to load store file."
Browser is Google Chrome 6.0.472.63 and Safari 5.0.2 on OSX
Hello mbed,
Mr.bontakun tried another acount on same environment. --> It didn't show any problem to load the compiler page.
So it seems it is not the user environment problem but the user account on mbed.org. There may be an object that cause of error when open the compiler.
Please check the files or settings for this user.
Thanks in advance & rgs / nxpfan
Have exactly the same and have send a mail to support@mbed.org. It started when I opened an example with a lot of Chinese characters.
Ben Zijlstra
Sorry about that - we are looking into the problem and hope to have a fix available soon. In the meantime, you might try the previous version of the compiler, following the instructions at http://mbed.org/forum/bugs-suggestions/post/5690/
Thanks,
Dan
Doesn't work for me. After a roll back I get a Fatal Application Error.
Will wait for further instructions.
Hi Dan,
After rolling back to the old compiler I got possible to look at the compiler page.
However,I get a new error "Fatal Application Error: Resource object failed to load. Please contact support and describe how you get this message."
I will wait for instructions.
Dan
Here the pictures you asked for:
Picture above: before rollback
Picture above: after roll-back starting compiler
Picture above: after clicking OK. A empty environment.
Picture above: after creating a new program.
It is same as Mr. Ben.
The fatal Application Error seems to have occurred when my programs is refreshed.
Can my programs be cleared?
I've fixed the problem with the rollback compiler - you should be able to create new programs now in rollback mode.
I will try and get a solution for the 'control objects' problem today. I will update this thread as soon as I have more info.
Dan
Hi Dan,
I can create new programs now.
But I still get a Fatal Application Error. So, I can not view later a new programs.
I look forward to updates.
Thanks,
I have temporarily fixed the issue for both bontakun and Ben.
The problem is related to having more than one compiler window open at once, so if you avoid that for now, the problem should not reoccur.
We are still working on a code fix for this problem, but hopefully the problem will be fixed properly very soon. If anyone else encounters this issue, please raise a support ticket or post here, and I will apply the fix to them too.
Thanks,
Dan
Hi Dan,
Ihave to make sure that all operations are normal.
Thanks for your supports.
Hi Dan,
All is working again. Glad you found the solution!! Thanks!!!
You need to log in to post a reply
